Mustang_Scotty Posted August 27, 2012 Report Share Posted August 27, 2012 (edited) Im looking at a 1991 lx with supposedly 29,900k on the ticker. Carfax does show good but I showed a mechanic friend of mine pics and the only thing he didnt like was the odemeter reading. He didnt like that the numbers werent lined up. He says that usually means rollback. And also he told me to look at the peddals for wear which makes sense. So I have included a couple pics. What do you think. Edited August 27, 2012 by Mustang_Scotty Quote Link to post Share on other sites
shelbymotorsports Posted August 27, 2012 Report Share Posted August 27, 2012 The odometer reading does look suspicious. And what is the seller saying about the repaint? Steve Quote Link to post Share on other sites
Bill Hamilton Posted August 27, 2012 Report Share Posted August 27, 2012 Back in the old day you normally could look at a brake pedal and tell by the wear. The upper right hand side would be worn to the metal around the 70K+ mark. Between 30 and 60K there would be much more wear on the right-side rubber as that's where most people would take their foot off the gas and catch the top of the brake pedal with their right foot. Look also at the driver's side seat belt on the left-side where it cross the seat. Extra wear would be noticable for a higher mileage car. I will say it looks clean underneath and the odometer number lineup doesn't look that bad to me. The 5.0LX's are tough little cars. I had two and one and sold one, a 1989, at 197,000+ miles and it was still going strong. The young guy I sold it to finally blew the motor running 150 shot of NOS through at 240,000 miles. The motor had never been apart and I had only replaced a timing chain at 180K. Quote Link to post Share on other sites
JeffJ Posted August 28, 2012 Report Share Posted August 28, 2012 (edited) I'm not as concerned with the odometer as the paint job and rust undercarriage. The fox body odometers do act like that quite regularly. Notice the 9 right behind the 2 lines up well, the next 9 has a zero behind it. The numbers don't tend to line up until the following number get's closer to turning over. They do regularly 'push' the next number up. I'm guessing in another 90 miles that the next 9 will be more lined up. Pretty typical on those cars. You being in NY, maybe the rust on the rear end cover, etc. is more common. Here in CO, I'd say no way. Over 100K, you would be more likely to see much more oil build up underneath. However that can be cleanned, so spend time looking in tight areas where it would be tough to get grime and oil build up. More pics of the interior seat condition etc would be helpful. The pockets on the doors look pretty good, those normally show much more wear with more miles. So looks believable to me, but somewhat questionable still. More pics of the overall car would be helpful. Heat usually eats up the foam on the AC lines going around the back of the motor over time. The lack of any seapage around the front crank and other things like that are making it look a lot more believable. Stickers on the coil cover, air cleaner box, etc. are making me think that the miles are really low. The cleanliness of the windshield washer lid and tank, etc. Looks pretty good. I'm leaning towards those miles as accurate. I'm guessing they did not like the color? Hopefully SVOC Jeff will see this and chime in. He is the Fox body master, but I think he would agree. Looking at that underhood pic, I'd say yea, those miles are accurate. Overflow tank, plug wires, clamps on all the lines-all factory. It all adds up other than the re-paint and rust underneath, but again, in your area, that is probably quite normal unless kept in a climate controlled garage. Edited August 28, 2012 by JeffJ Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 Why do you guys say re-paint> on this car with those limited pics I posted. This is supposed to be original paint. This car is in CA and Im in NY. The old story came out about a couple owned the car with the husband the died and she drove it sparingly. And the rust can happen IMO on any car sitting. My 2009 GT500KR with 900 miles on it has surface rust on the axle Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 And the seatbelt is perfect. I have more pics Quote Link to post Share on other sites
Helix Posted August 28, 2012 Report Share Posted August 28, 2012 I'll leave the mechanical aspect to an actual mechanic (looks good to me), but I'd like to chime in on the carpets and lining on the door. That is very very clean, although a Bissel green machine and some time could do that. However, there is so little wear that I'd at least assume that the car hasn't been abused by mud, boots, or crazy hot-rodders. Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 Its the repaint comments im worried about. I will post more pics in a minute Quote Link to post Share on other sites
JeffJ Posted August 28, 2012 Report Share Posted August 28, 2012 (edited) The color under the hood, that would be the color of the car. The car was not blue. All fox body mustangs had the same color under the hood as the rest of the car. See how the color changes from blue to gray at the very edge of the fender to under the hood? That is all one piece of metal where the fender bolts down to the inner fender. Ford did not paint the fender two different colors to match under the hood. If the car was blue, the prop rod and everything else you see under the hood would be blue. I think that car is supposed to be Titanium Frost. If so, the paint code in the door jamb would be YX. However, those do look like the original fenders, you can verify by the VIN code on the little white stickers you can see under the hood on the edge of the fenders. Those stickers should match to the vin number of the car. Edited August 28, 2012 by JeffJ Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 The color under the hood, that would be the color of the car. The car was not blue. All fox body mustangs had the same color under the hood as the rest of the car. See how the color changes from blue to gray at the very edge of the fender to under the hood? That is all one piece of metal where the fender bolts down to the inner fender. Ford did not paint the fender two different colors to match under the hood. If the car was blue, the prop rod and everything else you see under the hood would be blue. I think that car is supposed to be Titanium Frost. If so, the paint code in the door jamb would be YX. However, those do look like the original fenders, you can verify by the VIN code on the little white stickers you can see under the hood on the edge of the fenders. Those stickers should match to the vin number of the car. All the vins match. Could it be just the pic Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 (edited) Heres more... Edited August 28, 2012 by Mustang_Scotty Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 and more... Quote Link to post Share on other sites
JeffJ Posted August 28, 2012 Report Share Posted August 28, 2012 (edited) Interesting, so it was just the shadowing and the light that made it look dark blue. Looks good to me! Beautiful 91. Looks like a great car. Can you share the asking price? I'm not interested in the car, but interested in what they are asking for curiosity. I'm always watching the different Mustang values. Nice original Fox body's are getting very tough to find. Edited August 28, 2012 by JeffJ Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 (edited) But in turn on the air box pics the color does look shinier at the fender edge doesnt it? Edited August 28, 2012 by Mustang_Scotty Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 Interesting, so it was just the shadowing and the light that made it look dark blue. Looks good to me! Beautiful 91. Looks like a great car. Can you share the asking price? I'm not interested in the car, but interested in what they are asking for curiosity. I'm always watching the different Mustang values. Nice original Fox body's are getting very tough to find. I think I can get this for 7500-7000 Quote Link to post Share on other sites
grapepa Posted August 28, 2012 Report Share Posted August 28, 2012 check spark plug wires for date code.car all most looks to clean. Terry 07H350 Quote Link to post Share on other sites
Bill Hamilton Posted August 28, 2012 Report Share Posted August 28, 2012 Hey if it still has the rubber silencer in the fender by the airbox, buy it it's still a virgin. (LOL) Just kidding but it looks good and if the price is right and it's what you want ... Go for it. Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 Hey if it still has the rubber silencer in the fender by the airbox, buy it it's still a virgin. (LOL) Just kidding but it looks good and if the price is right and it's what you want ... Go for it. Airbox silencer still in there Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 Where are the date check spark plug wires for date code.car all most looks to clean. Terry 07H350 check spark plug wires for date code.car all most looks to clean. Terry 07H350 Where are the date codes again? Quote Link to post Share on other sites
JeffJ Posted August 28, 2012 Report Share Posted August 28, 2012 (edited) The wires have the year on them in black numbers. I would imagine they are correct. $7 to 7,500 would be very fair. I was thinking more along the $8,500 range for a car that nice. It would probably be worth close to $9,500 to 10K to the right buyer. The color being dull under the edges of the hood is very normal. Never get's polished like this car clearly is. Edited August 28, 2012 by JeffJ Quote Link to post Share on other sites
Bill Hamilton Posted August 28, 2012 Report Share Posted August 28, 2012 Airbox silencer still in there Then more than likely it's as it appears. That was the first thing we all did to our Foxes. I've got two floating around in my garage somewhere I removed back in the 80's and 90's. I owned two and loved everything but the seats. On trips over about four hours the seat would bother my back. I would roll up a towel and put it between the seat and the small of my back for comfort. They were probably two of the best daily drivers I ever had. Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 Does anyone know a reputable car carrier. Quote Link to post Share on other sites
shelbymotorsports Posted August 28, 2012 Report Share Posted August 28, 2012 Well things are looking better but if it were me I would have someone inspect the car. The CarFax mileage not matching the odometer raises a concern but the sellers explanation is plausible. I would check for date codes on the fan belt, sp wires and the head lights. If the car truly has 129k miles those items would have been replaced or in the case of the head lights, have lots of wear to the plastic. Another item to check are the brakes. Are the tinnerman clips still there. If the car shows no signs of a repaint then its looking even better that the mileage is correct. The one other item that sticks out is that this car has been for sale for at least several months, why has no one purchased it at the $8k price the seller is asking? Steve Quote Link to post Share on other sites
shelbymotorsports Posted August 28, 2012 Report Share Posted August 28, 2012 The recent smog check history looks good. Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 (edited) I think the discrepancy on the carfax has scared alot of people away. It did scare me also but I have talked to him several times. the headlights look great and from what he said was not replaced Oh and i did have an independent company inspect the car. It came back fine but I could tell they are not that knowledgeable. The paint thickness was 4.5 mils isnt that stock thickness Edited August 28, 2012 by Mustang_Scotty Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 You can clearly see that the carfax mileage is in running order and just cant jump from 24k to 129k then back to 29 so you cansee that happening. My friend owns an inspection station and is a classic car builder and he said it happens all the time. Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 The color under the hood, that would be the color of the car. The car was not blue. All fox body mustangs had the same color under the hood as the rest of the car. See how the color changes from blue to gray at the very edge of the fender to under the hood? That is all one piece of metal where the fender bolts down to the inner fender. Ford did not paint the fender two different colors to match under the hood. If the car was blue, the prop rod and everything else you see under the hood would be blue. I think that car is supposed to be Titanium Frost. If so, the paint code in the door jamb would be YX. However, those do look like the original fenders, you can verify by the VIN code on the little white stickers you can see under the hood on the edge of the fenders. Those stickers should match to the vin number of the car. Paint code is YG. YG Medium Titanium Met./Medium Titanium Metallic Quote Link to post Share on other sites
Mustang_Scotty Posted August 28, 2012 Author Report Share Posted August 28, 2012 (edited) I found the original listing. Edited August 28, 2012 by Mustang_Scotty Quote Link to post Share on other sites
