Team Shelby
TEAM SHELBY FORUM
Bunch of Fox body parts for sale
Not sure if this can be posted here but didn't see any other place for it.
I have a whole bunch of fox body parts I am helping a friend sell.
He would like to try to sell everything as a package deal, but will part out if he has to.
Please contact him with any questions.. robstern100@yahoo.com cell 201-370-9191
Looking to get $4500 for everything as a package deal.
Hooker headers for 351w for Fox body p/n 6223 new
Edelbrock Alum heads 202 intake valves, new…need to have one seal repaired
MSD distributor p/n 8384, soft touch p/n 8738, ign box p/n 6200, coil p/n 8223 with manuals
Oil pump p/n d9az6600a new with gasket and shaft (brown box in pictures)
Keith Kraft 410ci 351w short block with solid motor mounts and solid lift cam, new
JW Performance flywheel 164 tooth
Motorsport large capacity oil pan, new
Lakewood front struts p/n 40501, new
Edelbrock intake manifold p/n 2981, new
Oil pump p/n m 6600-b3, new, mounted for fit only (white box in pictures)
Gaksets: 2 sets intake gaskets (1 set oem), 2 sets fel pro head gaskets, 3 new style valve cover gaskets, 2 oil pan gaskets, oil pan side rails, timing cover and water pump gaskets, several water pump gaskets, front and rear crank seal
Motorsport polishes valve covers, some scratches, need a good polish, new
Comp Cams push rods p/n 7965-16 5/16”
2 timing covers, one older one newer
Steel valve covers and hold downs, new
JBA 1.6 roller rockers
Solid roller lifters
Motorsport spark plug wires p/n m-12259-c301, new
Federal Mogul main engine bearings p/n 7077m10for 351w, new
Liquid filled Pro Comp gauges, water, oil press, fuel, oil temp, Sport Comp tach with shift light, all used
Mr Gasket carb spacers with offset studs p/n 6005
Battery cut off with handle
Flowmaster single chamber mufflers
Hardened oil pump shaft
ARP head studs, used to fit heads only, new
