Team Shelby
TEAM SHELBY FORUM
caster camber plates installed?
I received all of my 427 Edition goodies in the box and I've installed or added everything except the caster camber plates. Does anyone have a photo of theirs that you could post for me. Curious to know what they look like inside the engine bay.
  • 2 weeks later...
  • 2 weeks later...
Here's a picture of my strut towers; I have the Maximum Motorsports CC plates installed.
I did the same thing...I see that you also surgically removed the required rubber bands for installation.
With the adjustable panhard bar, etc, I was able to get a 4 wheel alignment from my local, family owned shop.
UncleRonGT500KR
UncleRonGT500KR
I'm not sure I removed all of the rubber band on the passenger's side. I get some dull clunking on that side while slowly maneuvering the car; no noise while at speed. Had the front LCA's replaced per the TSB, but I still get the noise. I'll pull them apart some day to check on the noise source when I get new struts.
  • 1 month later...
UncleRonGT500KR
Ron,
I am eventually planning on using the MM caster/camber plates on my GT500, along with the FRPP handling pack and 20" Alcoa's.
I'll also be using a adjustable panhard bar for the rear axle to center it.
Who/which shop did you use? Not being from the area I'm at the mercy of new people I meet as far as shop recommendations.
I hesitate to take it to Phil Long even though Robert says they have a Shelby/SVT "specialist" Tech working there. When all is said and done, I want a GOOD, straight-up 4 wheel (preferably LASER) alignment.
What "mom and pop" shop did you use?
Phill Pollard
That just shows how stOOpid I am!
I thought the plates went on the outside (top) of the strut towers so I wouldn't be able to use the FRPP strut tower brace that comes with the Handling Pack. I feel like such a dummy!!
This is good news.....
Thanks for posting the pics,
Phill Pollard - Co. Springs
2010 Kona Blue/white GT500
