SNKBITE Posted June 9, 2020 Report Share Posted June 9, 2020 (edited) Has anyone gone wider than the 265/40 R19 Goodyears for tracking using the the same Cragar rims? Edited June 9, 2020 by SNKBITE Quote Link to post Share on other sites
SoCalSGT Posted June 10, 2020 Report Share Posted June 10, 2020 I don't track mine so haven't thought of it. I'm not sure I'd want to though, since when making a sharp backing maneuver the front tires sometime will rub. Especially if there's a bit of a bump or dip I'm backing over. I decided not to go with the Goodyear when I finally had to replace the tires due to age. Quote Link to post Share on other sites
SNKBITE Posted June 10, 2020 Author Report Share Posted June 10, 2020 Thanks SoCal. I may go the Boss route on the rears 285/35 19 keepIng the 265/40 19 which came with the car. Michelin all around is what I’m reading to be a good replacement. Quote Link to post Share on other sites
SoCalSGT Posted June 10, 2020 Report Share Posted June 10, 2020 That would probably work. I went with the Michelin Pilot Super Sport and I like the way they feel, and they are a little quieter than the Goodyears. Good luck and let us know if that works out okay. Quote Link to post Share on other sites
SNKBITE Posted June 10, 2020 Author Report Share Posted June 10, 2020 1 hour ago, SoCalSGT said: That would probably work. I went with the Michelin Pilot Super Sport and I like the way they feel, and they are a little quieter than the Goodyears. Good luck and let us know if that works out okay. Will do. Quote Link to post Share on other sites
T-K Posted June 12, 2020 Report Share Posted June 12, 2020 I did on mine, its a 2014 by the way, but still 19x9 I went up to 275/40.....my rim wont take much wider,Or at least its not recomended.... i also went from 265 front to 255. i think the best choice is to go 20 inch wheels, these cars need some wide tires with good grip. what was most dissapointing was that when we took off the wheels it said made in China😱 Quote Link to post Share on other sites
